Temps looking ok for 5960x?
Solved by LtRoyalShrimp,
My idle is ~38-44C, but I'm OC'd at 1.28v 4.375ghz...also on a custom loop, H60 will be dicey for load if you have roughly the same temps as mine :huh:
Idle temps are in the high 30's. Load temps at stock dont go over 60c(30 minute Aida64). Im happy. Have not done any OC yet, but it seems there is some room for it.
Macaw ·
Posted in Console Gaming3 -
4
Shahrad ·
Posted in LTT Releases5 -
8
frozensun ·
Posted in Graphics Cards8 -
kisserik93 ·
Posted in Peripherals11 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory14 -
3
