I'm building a computer for myself and after looking at CPU coolers I have opted for the Cooler Master Hyper 212 Evo because of constant great reviews although I am now considering getting a budget water-cooling set (£50). I have seen some by corsair around this price and I was just wondering if it is a closed loop (not custom) does this imply any risk for spillages? It'a probably a really silly question from 5 years ago but I'm a bit scared ;/
BLACKWIDOW: i5 4690k - MSI GTX970 - 2x 4gb GSkill RJ X - 256gb MX100 - 1tb WD Blue - NZXT H440
https://linustechtips.com/topic/229709-watercooling-first-timer/
AiOs will not spill unless you damage them, which is extremely rare unless you enjoy cutting the tubes of your AiO with scissors.
https://linustechtips.com/topic/229709-watercooling-first-timer/#findComment-3143803
I have to say, there is one risk everyone seems to be forgetting. When mounting an AiO, just pay attention to your screws. Don't over tighten them and pay attention as you mount the rad, you do not want the screw going to far into the radiator. If it does it can puncture the core and then you have a leak. This unlikely though if you use factory supplied screws. Just something to be aware of.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/229709-watercooling-first-timer/#findComment-3144619
Stay away from the cheaper corsair coolers as they have a high pump failure rate. If you really want an AIO look at the NZXT or Cooler Master line or just stay with the 212Evo. There have been instances of AIOs leaking but it is rare.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/229709-watercooling-first-timer/#findComment-3150392
I'm considering the ThermalTake Water 3.0 Performer, any thoughts?
https://linustechtips.com/topic/229709-watercooling-first-timer/#findComment-3160759
Those are good too but i have not had any experience with their support and i have with NZXT and Cooler Master and they are both great from my interactions with them.
https://linustechtips.com/topic/229709-watercooling-first-timer/#findComment-3161729
