I'm doing a physics lab analysis right now and they're asking for how consistent is my data. Through searching online, I realized that I could use the percentage of data that falls within one standard deviation from the mean to determine consistency. At what percentage is the data considered consistent?
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/229131-statistics-help/
That entirely depends on the experiment + how much you decide human error is
And how accurate your equipment is, if it was measuring to (say) 9 s.f. then your data is most likely going to be more accurate, and potentially more consistent, than it would be at 3 s.f. due to rounding errors etc.
"Maybourne, you are an idiot every day of the week; why couldn't you have just taken one day off?!" —Samantha Carter
https://linustechtips.com/topic/229131-statistics-help/#findComment-3136116
No, from the data collected was acceleration values of an object in free fall using a motion detector. If anything within one standard deviation of the mean would be considered normal (and therefore acceptable), then the percentage of data within one standard deviation would tell you how consistent the data is right? Or am I missing something here.
Link to what I searched up: http://teachertech.rice.edu/Participants/bchristo/lessons/StanDev1.html
Right now, I just don't know what percentage is considered inconsistent and what threshold is considered consistent.
https://linustechtips.com/topic/229131-statistics-help/#findComment-3136152
Oh looks like I was thinking about it incorrectly. The standard deviation just means the avg deviation from the mean. So of course there will be data values away from the standard deviation. I was treating the standard deviation as the mean, so I thought that the more values are away from the standard deviation the more inconsistent the values are. Turns out this is exactly what the standard deviation is. The larger the standard deviation, the more inconsistent the data is.
https://linustechtips.com/topic/229131-statistics-help/#findComment-3136292
