Disable crossfire and Vsync
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
Here's the problem- Chrome. Start Mincraft with Chrome shut and then proceed to open it; enjoy your newfound FPS! :)
I know it seems really simplistic, but it works for me. When I launch the game with Google Chrome open, I experience dramatic FPS drops and my FPS (despite running dual 670s) is about at 45-50fps. When I once randomly shut Chrome and opened Mincraft, it was at a rock solid 60. The key is to shut chrome before launching Minecraft. [i think other browsers too]
Let me know if it helps!
PC in Profile
First of all, what resolution are you running at? I'm going to assume you're running at 1080p. Also, what CPU are you running? Minecraft is more intensive on the CPU than the GPU, and the processor is often a bottleneck for it.
A few things you need to try:
Turn render distance down. It's notorious for tanking framerates. My single R9 290 and 4670k only just runs at 60fps with more than about 20 chunks of render distance at 1440p. Minecraft is a horribly optimised game and many people associate the simple looking graphics with high performance; this isn't true for minecraft.
Update to the latest AMD drivers at http://support.amd.com/en-us/download
Make sure Java is up to date (I believe 8.0 is the latest version) and you are running the 64 bit version (which minecraft now supports). To download 64 bit Java, you need to download it using a 64 bit browser such as Internet Explorer.
Make sure Minecraft has enough memory allocated to it. In-game, press F3 and look at the right of the screen. If the memory percentage is at 100% then it might be worth giving the program more memory.
Try disabling crossfire. I don't think minecraft is known to be one, but some games misbehave when running in crossfire.
If you're playing modded, try a vanilla world and texture pack and compare the framerate. Running too many mods could be a problem.
Ensure you aren't running framerate limiters or your GPUs aren't thermal throttling by running MSI afterburner.
Failing that, you've reached the point where reinstaling programs may fix the issue.
| My first build: http://linustechtips.com/main/topic/117400-my-very-first-build/ | Build for my friend's 18th: http://linustechtips.com/main/topic/168660-pc-for-my-friends-18th-with-pictures-complete/ |
ATH-M50X Review: http://linustechtips.com/main/topic/165934-review-audio-technica-ath-m50-x/ | Nintendo 3DS XL Review: http://linustechtips.com/main/topic/179711-nintendo-3ds-xl-review/ | Game Capture Guide: http://linustechtips.com/main/topic/186547-ultimate-guide-to-recording-your-gameplay/
Case: Corsair 200R CPU: i5 4670K @ 3.4GHz RAM: Corsair 8GB 1600MHz C9 Mobo: GIGABYTE Z87-HD3 GPU: MSI R9 290 Cooler: Hyper 212 EVO PSU: EVGA 750W Storage: 120GB SSD, 1TB HDD Display: Dell U2212HM OS: Windows 8
