So a couple of days ago I bought a few parts to get my pc together and when I tried to mount the cooler to the board I came across a problem. The board holes didn't quitee aline with the cooler. I have a msi z97 gaming 5 which is a soket 1150 and in the cooler manual says it works with the 1150 soket. So is it dificult to mount or did it come defective?
Thanks in advance!
https://linustechtips.com/topic/228096-hyper-212-evo-not-fitting/
Are you sure you're using the correct mounting hardware? Read the manual that came with cooler. It's no shame to read a manual when it comes to this.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
Are you mounting it in the right orientation?
Are you using the 1150 mounting bracket specified in the instruction manual?
im using a z97-d3h 1150 and has no issues mounting
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
I had this issue, it's a simple fix. The little thumb screws need to be push all the way down and turned sideways to be placed in the middle hole of the mounting bracket. Took me 15 minutes to figure that out. Im dumb. But it's okay.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
Maybe some pictures would be useful.
Yea I mounted the pc already with the stock cooler so I think there's not much I can show. I think the cooler is not defective but difficult to mount... The mounting thing it comes with does not aline with the board holes which is stupid... I think I might take it to some tech store and let them try to mount it. I hope they don't fuck my pc up xD.
What do you mean by sideways?
There are three places for screws in brackets. You need to push screw down and move it to middle one. It can be hard and frustrating and manual isn't really helping. But I have installed 212 in same mobo so it will fit fine.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
