Hey I just picked up the Corsair h110 CPU cooler and was wondering if you had to install thermal paste before using the cooler?
It should come with some thermal paste on the bottom. (If it's new)
You should see a greyish circle.  Like this:
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/227704-liquid-cpu-cooling/#findComment-3117380
 Well you still need thermal paste. It comes with it though.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/227704-liquid-cpu-cooling/#findComment-3117382
Corsair's AIOs' usually have thermal paste pre-applied, so If there's a grey coating then no additional thermal paste is necessary.
https://linustechtips.com/topic/227704-liquid-cpu-cooling/#findComment-3117385
why would you need thermal paste if it is allredy on xD
https://linustechtips.com/topic/227704-liquid-cpu-cooling/#findComment-3117392
Re read what i said.
https://linustechtips.com/topic/227704-liquid-cpu-cooling/#findComment-3117404
ooh oups :P
https://linustechtips.com/topic/227704-liquid-cpu-cooling/#findComment-3117449
@givingtnt
I made a thread about mounting issues regarding AIO coolers. I would buy my own and apply that instead.
http://linustechtips.com/main/topic/225444-aio-liquid-cooler-mounting-issue/#entry3088319
There's a simple way of knowing if the cooler is doing its job, and that is by monitoring the temperatures.
I wouldn't automatically remove pre-applied thermal paste and apply your own. Install it with the pre-applied paste and monitor temperatres; if all is in check then it's fine.
https://linustechtips.com/topic/227704-liquid-cpu-cooling/#findComment-3117590
@givingtnt
well. I don't have any problems with my h80i's coolingcapabilities. it keeps at iddle a nice 42 degree on a i7 4790k @ 4.6 Ghz
https://linustechtips.com/topic/227704-liquid-cpu-cooling/#findComment-3117600
