Anyone know that form factor for ITX that is as long as it (170mm) but is not as wide (about 120mm) and if there are any boards with a relatively modern socket/CPU on the market?
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/226877-smaller-than-mitx/
Nope. How about a nuc? Whatcha thinkin bout?
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107313
an Intel NUC or Gigabyte Brix would be your closest bet.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107317
Maybe this helps...
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107318
Sinclair ZX spectrum build ;)
http://www.youtube.
Maybe this helps...
this is all expensive (maybe the nuc not, but thats too small i think, would leave unwanted holes
i know a form factor is defined. its not called thinITX but its something similar... @DEcobra11 knows it exists too
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107328
There's thin mini ITX, nano ITX and pico ITX, but I don;t know the availability of the latter two. TMITX is mainly used in all in ones and microservers, and so far as I know is compatible with the more recent intel chipsets, but I don't know which.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107361
its neither of those. its literally just not as wide as mITX :/
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107385
Raspberry Pi?
ARM based. need windows
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107406
something with embedded atom?
like? it has to be <13cm in width
What do you plan on using this for?
a SuperSFF build
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107461
I can see that.  I meant as in... light web browsing, emulators, etc... the purpose overall?
browsing, docs editing, just something relatively small and a cool looking thing
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107480
do you plan on having the keyboard fully functional?
INTEL i7 4790K | GIGABYTE GA-Z97X GAMING 5 | A-DATA 16GB | PCS+ R9 290 | SAMSUNG 840 EVO | MOMENTUS XT BARRACUDA |  FRACTAL DESIGN R4
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107492
yeah, probably gonna try to reuse the original, since it works, just need to find some documentation on its interface
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107500
this kinda
http://buy.advantech.eu/Pico+itx+Atom+Pico+itx+Pico+ITX/MIO+2260NF+S6A1E/model-MIO-2260NF-S6A1E.htm?country=Slovenia&token=635479300631043779
http://www.kontron.com/products/boards-and-mezzanines/embedded-sbc/pitx-25-sbc/
try to find in shops
its called pico ITX, maybe there are also other names for other sizes.
just search intel atom embedded i am too lazy
https://linustechtips.com/topic/226877-smaller-than-mitx/#findComment-3107508
