Okay so the internet is (in my eyes) have been divided between the whole bendgate thing and others saying that it takes greater force, etc.
All I wanted to know if it's worth getting the 6 plus, and did Apple suffer with the new generation of iPhone 6's that it's not worth getting?
Thanks guys
https://linustechtips.com/topic/224945-iphone-6-plus-help/
Just don't be an idiot and nothing will happen to it. They're fine. Only a handful of phones were bent, out of millions sold. Those are excellent numbers.
Pretty much all of them can bend.
https://linustechtips.com/topic/224945-iphone-6-plus-help/#findComment-3081494
Thanks guys
If you like iOS and like the design of the i6+ then I'd say go for it. The recent updates have been glitchy, but I'm sure Apple will iron those out. I'm not sure how easy the iPhone bends with real world usage, but if you get a case it shouldn't be an issue(it would fix the protruding camera also).
https://linustechtips.com/topic/224945-iphone-6-plus-help/#findComment-3081529
go for it. There are 9 Iphone 6 that bend out of millions. And all smartphone can bend:
 Firs number isthe deformation point and the second the screen spliting point
HTC One (M8)                        31,7 Kg             40,8 Kg
Apple iPhone 6                      31,7 Kg             45,3 Kg
Apple iPhone 6 Plus              40,8 Kg             49,9 Kg
Apple iPhone 5S                    59 Kg                68 Kg
Samsung Galaxy Note 3       68 Kg                 68 Kg
LG G3                                      59 Kg                  59 Kg
"Strength does not come from winning. Your struggles develop your strengths. When you go through hardships and decide not to surrender, that is strength" Arnold
https://linustechtips.com/topic/224945-iphone-6-plus-help/#findComment-3081549
Regardless of bendgate, the iphones offer (as they always have) some of the worst value on the market. Get an LG G2, it's half the price and does pretty much everything just as well if not better, it also has an sd card slot, a removable battery, a 1080p screen and android gives you a LOT more freedom. What's the point of having more power if you can't use it because of software restrictions ^^?
If you have any questions feel free to pm me. I'll be glad to save you a ton of money ;)
sudo chmod -R 000 /*
https://linustechtips.com/topic/224945-iphone-6-plus-help/#findComment-3084064
The iPhone 6 plus is HUGE, regardless of bendgate blah blah blah I would consider going Android or a regular iPhone 6. iOS on a 5.5" display isn't as great imo, you'll get sick of reaching to the top left corner to press the back button.
My hands are a bit larger than average, and I held the 6+ and that hasn't been a problem for me @jezza39
That's what I thought so to, but a lot of people says Apple lies and will go up as days go by @AlwaysFSX
It looks like a great phone but at the price it's kinda hard to choose that over the G3 or any other flagship phone
I'm giving iOS a try this time around :P I haven't looked into the G3 however. @zapsyou
That is what I was thinking, even if the phone is thin I always get a case, rather be protected. @QueenDemetria
LG G3 59 Kg 59 Kg
I have seen those reports, but like it seems like people still disregard it and says it's completely different on day-to-day uses @Lavachyste
I am probably going to buy an iPhone 6 Plus, I doubt that it will bend, as it has only really happened to a handful of phones.
I hope you have good luck man, let me know how it goes? @mdnorman38
Well I am upgrading so I'm not buying the phone outright, and I had an android device but I'm not a fan of the operating system:P not saying it's bad at all, I just don't take full advantage of the openness :P but thank you for the advice! @Sauron
https://linustechtips.com/topic/224945-iphone-6-plus-help/#findComment-3084779
Even if you don't take full advantage of it, it's half the price  ^_^ there are great ports of pc games (such as doom 3 and quake 2) for android, whereas none of that exists for iphone, that's thanks to the openness even if you personallydon'thave to do anything special. On the other hand you might not be interested in mobile gaming, however at that point one has to wonder why you'd spend more than 200$ on your phone... there are excellent options at that price if you don't do anything intensive with it.
https://linustechtips.com/topic/224945-iphone-6-plus-help/#findComment-3085522
