Looking at upgrading from a Iphone 4s to an android phone. Have been looking into the LG G3, HTC One M8 and the HTC Desire 816 but still can't decide.
I mostly just watch movies and listen to music over the speaker and occasionally play games but not often.
Any recommendations?
*EDIT: Photo quality is important*
https://linustechtips.com/topic/224392-smart-phone-advice/
M8 has got great speakers and pretty good power for games. I love it. Especially once you root and unlock it.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073650
Note 4? It has a better processor then the G3. a good-ish speaker, big display... vibirate display for movie watching (over saturation shouldn't make too much of a difference) and it's just good looking in general.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073655
Personally I like the Samsung Galaxy S5.
The camera is fantastic, Waterproof, and a bunch of other cool things.
I personally don't like aluminum on anything, its just not a good material to use in phones imo.
Or the Note 4
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073662
i have no idea what rooting is or unlocking. i saw a guide for it so i will head there and learn.
Unlocking it makes it so you can change the ROM(Basically it's OS) and rooting gives you access to admin features kinda like jailbreaking. It gives your phone full functionality.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073665
HTC is coming out with an M8 that has a proper 13mp camera. I'd probably just wait for that as it seems to be exactly what you're looking for.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073670
 Well then! The Galaxy S5 has a really good camera, has all the jazz (16MP, Slow motion @ 240FPS, Good colors, etc)
I can get you some sample pictures if you want
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073682
xperia z3 it has equal quality front facing speakers as the htc one m8, one of the best camera's for a phone, 5.2'' FullHD comes with great earbuds and is powerfull
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073691
It's all good, 16mp is impressive for a phone camera and sure beats the 8MP of the iphone4s :D
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073701
Take a look at it :) See what you think
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073715
It also voids the warranty (not that that's the end of the world)
Normandy - Intel Core i5 3470, 8 GB Corsair Vengenace LP, EVGA GTX 960 SSC, Gigabyte GA-Z77M-D3H-MVP, WD Blue 1 TB, Seagate 320 GB (steam), Seagate 320 GB (experimental, second OS, etc), Windows 8.1 + Ubuntu 14.10
Garrus - HP Stream 11
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073720
not a big fan of the button layout of the new Xperia phones.
it's the same as my xperia z (original one) and i love it, thumb is exactly on the power button and you can just roll the middle of your thumb over the volume button
(and that dedicated power button :wub: )
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073729
Oh yeah, @Meetchell I probably should've pointed that out sorry. From what I've heard though if it's a physical defect the warranty is fine, but software defects you can't use the warranty.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073732
Xperia Z3's screen is bad colour wise :( Z2 was so much better. But everything else is nuts on Z3.
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073752
It depends. I had a chat with HTC who said they would be able to know even if you s-offed, disabled tampered, disabled relock etc., and as such wouldn't cover hardwear defects, but I've also heard what you said. So basically, YMMV.
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073756
I see how its extremely ergonomic for use but i feel i would constantly hit it the way i hold phones. I used to have a low end Xepria something which although terrible was an ok phone.
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073770
i don't have that problem, but everyone is diffrent, you should just go to the store and hold it in your hands to see if it fits your hands
https://linustechtips.com/topic/224392-smart-phone-advice/#findComment-3073783
