Hi all yesterday my 780 ti started playing up. I have been playing ac black flag for last 2 days without fault but yesterday it starting lagging heaps to unplayable fps.
I have tried all my other games and they are all doing the same thing now even when they used to pull high fps.
I have reset the whole pc to stock clocks but that didnt help.
Is my gpu on its way out?
Thanks in advance.
CPU: 4690k - 4.5@1.29v  GPU: GTX 780ti - core +100 / Mem+350 Motherboard: Asus Z97-A  SSD: 256Gb 840 Evo HDD: Seagate Barracuda 1TB  RAM: Corsair Vengance Pro 2x4Gb  Case: White H440  PSU: RM850  Cooling: NZXT Kraken X60
https://linustechtips.com/topic/224249-780-ti-dcu2-problems/
Maybe you played too long and killed it or maybe windows switched over to the onboard CPU graphics
https://linustechtips.com/topic/224249-780-ti-dcu2-problems/#findComment-3071612
What is your GPU usage at idle and at load?
https://linustechtips.com/topic/224249-780-ti-dcu2-problems/#findComment-3071623
I'd check what @Enderman said and check your temperatures too.
No and no..
Yea... qq
https://linustechtips.com/topic/224249-780-ti-dcu2-problems/#findComment-3071720
Ok I will check when home from work and post a screen shot up.
https://linustechtips.com/topic/224249-780-ti-dcu2-problems/#findComment-3072800
This is it at idle and load playing ACBF. I did reinstall the drivers and it seems to have worked i think as its acting normal for now.
https://linustechtips.com/topic/224249-780-ti-dcu2-problems/#findComment-3073419
Ok, let us know if it happens again.
https://linustechtips.com/topic/224249-780-ti-dcu2-problems/#findComment-3075098
