I plan on getting a new case and i'm having trouble deciding on what to get.
I really want something portable.
there are plenty of cases in my price range ($100 or up to $140 if it has fan controller).
I am mainly looking at the cm storm scout 2, or the cooler master storm trooper.
those are the only ones that i could find that i seem to like.
If you have any recommendations that would be awesome.
Trooper: http://www.ncix.com/detail/cooler-master-storm-trooper-eatx-8c-65340-1342.htm
CM storm 2: http://www.ncix.com/detail/cooler-master-cm-storm-scout-32-76621-1342.htm
https://linustechtips.com/topic/223701-portable-atx-cases/
fractal arc midi r2
Specs
https://linustechtips.com/topic/223701-portable-atx-cases/#findComment-3064381
What means portable to you?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/223701-portable-atx-cases/#findComment-3064391
You can just carry the case you know, right? I use a NZXT H2 and use it for LAN all the time. Maybe look at an H440?
https://linustechtips.com/topic/223701-portable-atx-cases/#findComment-3064421
@RevoltTrain
A sturdy handle
The Corsair C70 has quite sturdy handles, I can confirm this as I'm a proud owner of one.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/223701-portable-atx-cases/#findComment-3064427
Do you live in the lower mainland?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/223701-portable-atx-cases/#findComment-3064455
@dizmo
Indeed i do
I think NCIX has one of the first cases kicking around their warehouse as an open box item.
https://linustechtips.com/topic/223701-portable-atx-cases/#findComment-3064470
c70
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/223701-portable-atx-cases/#findComment-3064492
Corsair Carbide Spec series are tiny for an ATX chassis
Asus MAXIMUS VII Gene 2 x 8GB G.Skill 16GB 1600 Mhz Intel 4670k @ 4.3 Ghz Corsair H100i w/ stock fans EVGA GTX 770 SC Intel 750 Series SSD 240GB, Samsung 840 SSD 240GB WD Caviar Green 2TB Seasonic X-650 V3 2 x 140 mm Noctua A14 PPC, 120mm LED Corsair AF120
https://linustechtips.com/topic/223701-portable-atx-cases/#findComment-3066492
