I would get a 400W 80+certified or above PSU
https://linustechtips.com/topic/223430-minimum-psu-required/#findComment-3060882
I always used to recommend the bare minimum wattage, but the efficiency peak of power supplies is ~ 50% usage, so I would get a little more than you need.
https://linustechtips.com/topic/223430-minimum-psu-required/#findComment-3060903
For that GPU even a 400W unit is a bit overkill, usually the Corsair CX 430 (430W) can be found for dirt cheap.
Personally I think investing on a high quality unit and forgetting for the next 5+ years about the PSU in your system, even if you upgrade the GPU several times; it's a smart move. But I do like investing money on the rig, for many people buy once and replace several years later when it can no longer keep up, is the way to go.
https://linustechtips.com/topic/223430-minimum-psu-required/#findComment-3060932
400W for sure. Anything over that would be redundant, unless you plan on upgrading in the next 2 years. Then 500 would be safe for pretty much anything.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/223430-minimum-psu-required/#findComment-3060992
