Computer Part Picking Help
If the plan is to add additional gpu then I would suggest going with the i7-5930K instead of the i7-5820K. The later has 28 PCIe lanes which only allows for x8 operation of a second gpu.
A 750W psu is enough for a 2 gpu system with heavy overclocking. You might even consider something smaller.
With two identical 1TB hdd I presume some sort of RAID array is contemplated. In that case WD Red drives would be more appropriate. They are designed for that sort of use.
Fans are something that can always be added when and if they are needed. It seems pointless to me to spend the equivalent of a decent case on aftermarket fans for a build that will not be putting out much heat.
The better performance of an 850 Pro ssd will not be noticeable in a general use and gaming rig. Something like an MX100 or 840 EVO would do just as well, further reducing the cost.
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor ($564.99 @ NCIX US)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($89.99 @ Newegg)
Thermal Compound: Arctic Cooling MX4 4g Thermal Paste ($6.98 @ OutletPC)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard ($395.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2666 Memory ($299.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($109.97 @ SuperBiiz)
Storage: Western Digital Red 1TB 3.5" 5400RPM Internal Hard Drive ($65.29 @ B&H)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card ($629.98 @ NCIX US)
Case: Corsair 750D ATX Full Tower Case ($129.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ NCIX US)
Keyboard: Corsair Vengeance K70 RGB Wired Gaming Keyboard ($169.99 @ Newegg)
Total: $2618.44
Generated by PCPartPicker 2014-09-26 12:35 EDT-0400
