A few monitor questions.
DNX
Okay my current display went out :( now I'm gonna upgrade and need a few opinions from you guys! Okay I've narrowed my choices to the lg 21:9 35UM65 2560x1080 I really like the 21:9 aspect! Or should I get a true 1440p display? My current gpu is the gtx 980 if you guys needed to know. Please and thanks guys!
Will be using mostly for gaming
Just like 1080p doesn't look so great @ 27", 2560x1080 doesn't look so great @ 34". Just something to think about. ;)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
So should I get a 1440p or save up and get a 3440x1440p 21:9? And have to get another gpu?
Well it's entirely up to you mate. If you like the look of the LG one then yes, save a bit more for the LG 34UM95. As far as another GPU goes, you've got a pretty powerful one already. That should be more than adequate for your needs. ;)
Anyone else help me out?
No, they've all gone to bed. :P
Lol I guess they did
