It is capable of cooling a 9590 in most conditions but seeing as coolers are primarily affect the most my your own ambient temps we can't guarantee what the performance would be like or if ti would be able to cool it at all.  If you tell us what your average ambient temps are then I would feel better about telling you if that cooler would work for you.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027304
The H100i should be able to handle the FX 9590's heat, but definitely not 40C under load..
That being said, if you didn't buy the 9590 or an AMD board yet, you might want to look for an Intel alternative.
I'm not saying that AMD is bad (I have an AMD GPU in my system), but, for the same price, you can get something that would have similar performance, but way lower power consumption and heat output, at about the same price (for example, the Core i5 4690K).
If you've already got the 9590, yes, as I said, the H100i will be able to keep your CPU to safe temperatures.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027324
Unless the OP's ambient is too high, remember the maximum safe temps for AMD CPU's is around 60c.
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027347
uw0t? 60c? they are safe up until 85c
no, AMD FX CPUs are rated safe for 62c according to AMD.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027368
That CPU cooks shit! The H100i can probably handle it on stock clocks. Butboverclocking will kill that thing.
the 9590 is already fully overclocked by AMD most of them can't take much more anyway and they alreay have the max 1.5v safe dialed in...
The 9590 is an highly overclocked 8350...you can't get much more overlock out of an already highly overlocked CPU...
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027387
^These
The highest OC I've seen on a 9590 that was a daily use clock was 5.4Ghz and it required 1.6v. 9590's are pointless really, an i5 would be a far better investment.
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027400
^These
or an i7 for multi-threaded tasks such as video editing, rendering, 3d modeling, transcoding etc...
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027418
the 9590 is already fully overclocked by AMD most of them can't take much more anyway and they alreay have the max 1.5v safe dialed in...The 9590 is an highly overclocked 8350...you can't get much more overlock out of an already highly overlocked CPU...
Yeah, i wouldn't recommend it either. But it's a well binned CPU, i have seen articles stating that 1.58V or more are possible but a H100i can't handle that.
who cares...
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027594
it's always possible until it pouff out.
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3027606
Thanks guys!
I got a intel platform now but i dont like it atleast what i got in haswell z97 deluxe and i5 4690k because of the lack of cores and a example of is when like League start while looking at youtube league of legends crashes -.- i dont knwo why the games crash and other while using chrom.
and my last computer could it and i had a AMD fx 8120.
Which leads me to amd again :P if you got soemthign about my problem with the i5 tell me =)
https://linustechtips.com/topic/220842-cooler-for-cpu/#findComment-3028505
