Are they really that loud??? I just ordered 2 PPC NF12 and 3 NF14. The reason i ask this i s because I've been looking at videos and people are saying that they are kinda loud, so if they are what RPM should i set them at for them to be silent.
2000 RPM or 3000 RPM?
The 3000 sounds like a jet engine taking off, and I had to turn it down as it's just too loud.
2000 is still unbearable, for me at least.
I like <1500 RPM.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3007908
The NFA14 is terribly loud at 12v and to a lesser extent at 7v. However at 5v it's very quiet.
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3007910
I like <1500 RPM.
well i bought them both at 2000 RPM with PWM, so if I'm gaming would they still go loud?
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3007921
Yes, I'm pretty sure that it would run at 2000RPM unless turned down in the bios/software.
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3007932
So when I'm gaming what Voltage would they be at, I'm sorry i dont really get the Volt measurements for fans, i just somewhat understand RPM
You have complete control over their rpm, so you can limit their rotation to whatever you want.
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3007935
So let say, what RPM should i run if my PC is idle to be silent?
Nothing moving is silent. If you want it as quiet as possible, lower the fan speeds as much as you can while keeping acceptable temps. If quiet was your goal, getting Industrial Noctuas was probably not the best idea when they are essentially higher rpm versions of the normal Noctua fans.
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3007964
Yeah, i kinda second guess myself when i bought them, you see the reason i went with these is mostly cause Linus seems to really like them and Noctua in general, and seeing that their best fans are now black, it was just a must, so i just did it for the shallowest reason so yeah, I'll try to get the RPM to my liking, thanks for the advice
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3007975
At full speed or 12V, they will be loud, because they're made for.. Industrial use. But you can easily undervolt them to make them a lot quieter (in-line resistors or fan controllers).
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3007998
As low as possible. I have mine at around 600 I think and my case fans stay like that all the time. When under load the only fan that speeds up is my CPU fan.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3008115
noiseblockers are way more silent, and different tone
dont buy industrials for pc use lol, cus you have to run them at low speed anyway
The 120mm industrial noctuas cost the same price as standard 120mm ones in Australia. Some people prefer their appearance.
https://linustechtips.com/topic/219409-noctua-ppc-noise/#findComment-3012851
