I got my new system running, everything turns on ok. I have a blank hard drive and a copy of windows 7. What do I do now?
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/219340-help/
Have a party!
Just install windows 7 on the hard drive...
https://linustechtips.com/topic/219340-help/#findComment-3006982
How? I don't now how lel
Is it on a disk or a USB stick?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/219340-help/#findComment-3007020
No its on a disk
Quote people if you want them to know about your posts. Does your build have DVD drive? If not, you need to make ISO out of disk and "burn" .iso image to USB stick. Then set USB to be first boot device from BIOS and go for it. For completely new build you don't have to worry about erasing important files. If you have SSD and HDD, you can unplug HDD during install to be safe.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/219340-help/#findComment-3008052
When we try and boot right now, we can't see the bios, only an error message from asrock saying to reboot and select proper boot media.
We tried opening the bios while using a different hard disk.  Is that bad?
https://linustechtips.com/topic/219340-help/#findComment-3009999
You don't even need any drives to connected for entering BIOS. Your POST screen will show key which you press to enter. Usually its DEL or F2. Trying to boot into wrong hard drive usually results as blue screen or boot loop.
I'm guessing that your boot order is messed, thats why you get that message. It has HDD set as first but since there's no OS, it isn't valid.
https://linustechtips.com/topic/219340-help/#findComment-3010027
How do I fix this?  When I try to fit delete on boot, I automatically switches to the screen I described above.
https://linustechtips.com/topic/219340-help/#findComment-3010064
Google tells me that right key is F2. Can't verify, my Asrock board is too far away .)
https://linustechtips.com/topic/219340-help/#findComment-3010096
K i'l try that when I get to my friend's house later.  Will you still be online in an hour?  Thanks for all your help BTW :)
https://linustechtips.com/topic/219340-help/#findComment-3010135
Yeah, I'm up until 23CET.
Think we solved the problem, drive was bad lel
https://linustechtips.com/topic/219340-help/#findComment-3011149
