Is a sound card worth it?
ryecribbytree
I'm buying the hyper x cloud linus did a video on and i'll be using on board sound from my MSI 970A-G46. In logans video he noted they were 62 ohm and he advised an amp/dac but that is a little expensive.
if you are going to use high impedence headphones like 80+ ohms than yes you should get a sound card but if not just get a motherboard with the right outputs for your headphones.
CA-RIP, Cz up hoes down, bang these hoes out with my rounds.
I'd say nah imho Sound Cards are more for if you want more Audio in/out puts AmpDacs are if you want better sound
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
I would get a DAC.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
