Is going from an i3 to an i5 really worth it?
Solved by LemonSpice,
I have an itx Gigabyte b85n Mobo as i said in my first post, so that throws out that possibility without spending more money.
then i would go with a http://www.amazon.com/dp/B00D697PEG/?tag=pcpapi-20 as it is 4 cores 8 threads and it works with your mobo and it is better than the i3 or the i5 its about as good a s a i7 4770
Featured Topics
Worstcaster ·
Posted in Peripherals2 -
3
5
davidholzapfel09 ·
Posted in New Builds and Planning4 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
