Case Side Panel Idea! Will it be worth it?
Solved by LogicalDrm,
So would you say to intake and pull air in or pull the air out ?
I can put 120mm fans on the side instead of the 95mm.
But I didn't have any on hand.
In. Reference cards intake with that one fan and blow hot air out from back. More fresh air, cooler they run. And with lower fan speeds.
Featured Topics
6g2 ·
Posted in Troubleshooting0 -
NickKz ·
Posted in Programs, Apps and Websites5 -
JakubR88 ·
Posted in Graphics Cards8 -
3
ollo ·
1
