4770k OC Issue
Even if it's a touchy beast, if it makes the PC crash... then the oc is unstable in my eyes.
I'd up the voltage a tad more as long as your temps are fine, or you could try to lower the clockspeed and see what that gives if you're not comfortable with higher temps.
Got it sorted out this morning. Regardless of voltage, BF4 crashes @ 4.6 Ghz, which being that it was the only thing to crash made me think there's something about BF4 that won't run properly at those speeds (at least in my machine). So, I backed it down to 4.5 Ghz @ 1.22v, which I had previously determined was stable with AIDA64, and BF4 ran fine. So, I'll be leaving it there. Temps topped out at 55 C
Gotta love 240mm AIO's
Thanks for all your help guys! The LTT Community has been a huge factor that has made my current Gaming/Future Productivity Machine possible. Linus really has created a great thing here without a doubt.
