Was wondering if you could recommend a decent manufacturer of LED strips to light the case from inside. And I also wonder what powering options are there available for such LEDs, e.g. 3/4pin mobo connectors, PCI slots etc., which of these is best in terms of reliability and power consumption?
https://linustechtips.com/topic/213420-led-strips-inside-the-case/
Bitfenix Alchemy LED strips powered by molex.
I love my NZXT LED's, they're wrapped in a black braid, so no ugly circuit.... However i'm on my second set, perhaps my first were just faulty? But either way they do a good job at illuminating my case!
Colour balance looks a little purple in the picture, but there not remotely purple!
Guys you shouldn't buy branded led strips, they cost too much...
On ebay generic led strips cost 1$ per meter if you buy 5 meters, if you more they cost even less, they're so cheap! Then you just need to make a connector for it, I usually take old 80mm fans with molex connector, toss the fan and just keep the cable where I attach the led strip. Also you could use Molex splitters for this purpose, they will work the same. Also you could buy paracord to do a cool sleeving job, and it will look just professional and neat as the branded ones, and you made it yourself, so it's even better!
OS: Windows 10 - Kubuntu 15.10 - Mac OSX El Capitan  CPU: i7 4790 @ 4.00GHz  MOBO: AsRock H97M Pro4  RAM: 4x 8GB Kingston HyperX @ 1866MHz  GPU: VTX3D R9-280 X-Edition  CASE: iTek Spacebox w/ Arctic Fans  PSU: Corsair X750M  SSD: 250GB Samsung 840 Evo  HDD: 3TB Western Digital WD30EZRX  DISPLAY: 3x Acer P193W  MOUSE: 5$ Chinese  TOUCHPAD: Logitech T650 Touchpad  KEYBOARD: Perixx Px-5200 w/Mx-Blues
That's right, it haven't got any difficult to buy one of those led strips, and just plug one of the sides to molex 12 and the other to the ground cable. You could even add a switch, and turn it on and off as you wish
Learning from Spain, don't be rude if I can't understand everything you write down to me O_o'
i actually fried a bunch of leds doing this. and they weren't shorted out either... :huh:
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
Idk, I installed more than 10 meters of led strips and never fried a single led...
Yeah i was thinking about it, and i realized that the leds were meant to be run off 4.5 volts instead of 12 volts. :blink:
That's not a reason to fry a led. Probably that would have happened that planets weren't aligned yet....
