290x or 780ti or titan black
or maybe 295x2 if you consider that a single card
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876522
290x or I agree with Enderman, 295x2 if you consider it a single card
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876535
If it´s not a problem for you a R9 295x2 could be a nice solution. Just make sure your PSU has enough power to provide. But the R9 295x2 is at the same price point pretty much than the Titan Black.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876537
This is my current setup.
My second PCI slot has shit it self so i thought instead of upgrading the motherboard i would sell the two gpu's and buy a single which can do a similar job. So dual cards is out of the option currently have enough power also.
CPU - Intel i7 3770K 3.5GHz(3.9GHz Turbo)
· CPU Cooler - Corsair Hydro Series H80 CPU Cooler
· Motherboard - ASUS MAXIMUS V Formula 6-Core Ready Quad-Chn DDR3 USB3 SATA3 CF/SLI Ready
· RAM - Gskill 8GB(2x 4GB) DDR3 1333
· Graphics - HIS 7970 3gb.
· Graphics - HIS 7970 3gb. xfire Bridge
· Primary HDD - Intel SDD160 Series 3 160GB SSD SATA III 6GB/s Max Read/Write: 550/520(MB/s)
· Second HDD - WD BLACK 500Gb SATA 3
· Second HDD - WD BLACK 2TB SATA 3
· Optical Drive - DVDRW
· Case - ANTEC P280 GAMING CASE
· PSU - OCZ Fatalty 1000w Modular 80+ Gold
· Tripple Screen Stand
· 3 Acer LCD Monitors G235H
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876569
What would be a good single card replacement for a dual 7970 setup.
Need it to run tripple screen for racing titles
Nothing. Dual 7970 = Dual 280X which is better then any single GPU right now. 295X2 or Titan Z would be the only single card upgrade
"Rawr XD"
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876570
then 295x2
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876580
Your system is really okay and a single card to replace a 7970 CF is not available at the moment :). But you could also look into a R9 290 CF. You would get almost the R9 295x2 performance and would be even cheaper :).
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876593
then 295x2
Why dont you try to get a MOBO for the cheap?
2x 7970 is still enough IMO
Problem is I cant run 2 cards anymore second PCIE slot is malfunctioning. So which single card can run three screens and would be good for a future sli or crossfire setup.
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876792
The 295x2 is a single card, dual GPU.
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876796
Yeah then the R9 295x2 seems to be the best case scenario. And you should be able to sell that 7970 CF for a fair price and then the R9 becomes even more attractive :) .
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876803
WOW that card is $2000 in aussies might need a more budget solution
Then a 290x is the next best thing...
I highly doubt the titan z will be less than that xD
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2876873
can that handle three screens on the one card
it can, but depending on the games it may not be the most optimal solution. how about getting a different mobo?
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2879022
might have to be a mobo upgrade but the sucky part is i will have to learn how to.
Do you know if on the maximus board can you run a single GPU on the second PCIE only or do you have to start from the first slot.
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2879151
its not hard. take off the ram/gpu/cpu/cables
get a new mobo, install them, clean the old thermal compound, install new, plug it all in again
voila
and it works, but in an x8 mode
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2879173
290X or 780ti <  doesnt even come close to 7970 x2.   would be a for sure downgrade. Get a new Mobo and learn how to build.
my system
Intel I5 3450
Sapphire 7970 X2 crossfire
16 GB RAM
Wouldnt trade my 7970's for ANY single card out there.
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2879209
If you really want to change your motherboard, which is by the way a good plan, because having a board that is already damaged, wouldn't make me sleep very well hehe, I would buy the board and prepare myself.
If it is the first time you want to do this. Get the motherboard and some thermal compound. Besides that get a laptop, tablet or another PC or your cell phone ready and watch PC building guides. Stop the guide always at the step you are at this point. That will help you a lot.
Linus has some awesome PC build guides on Youtube, or JayZ 2 Cents or Paul's Hardware from NewEgg.
If you change the motherboard (and maybe a new CPU cooler, IDK what you've got right now) you can keep on using that 7970CF and end up way cheaper than buying a new GPU.
I would not change a 7970CF for a single R9 290X or 780Ti. CF/SLI systems are running butter smooth nowadays. AMD and nVidia did good on that side.
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2879241
voila
voila
my system
Intel I5 3450
16 GB RAM
So time for a new board then I Currently have a asus rog maximus 5, what would you guys recomend as a replacement. my pc specs are below.
. CPU - Intel i7 3770K 3.5GHz(3.9GHz Turbo)
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2883705
As long it has Crossfire support then its going to bo more of what you prefer or want in other features......I have an ASUS P8Z77-V LK works great for what i need it to do has enough features to be a good contender at a decent price point.   And im running Dual 7970's with it ...its ben a great board.   Had GTX 470 SLI in it before i upgraded to the 7970's
https://linustechtips.com/topic/211924-dual-7970-replacement/#findComment-2884283
