what kind of LED strips? RGB? controllable? colour?
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2872792
bitfenix alchemy LED strips come in blue :)
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2872806
I'm so tempted to go to Home Depot and but an orange bulb and wire something together for my psu so it works in my case. :P
Hi i'm looking to purchase some blue LED lights to put in my computer case(Phanteks Enthoo Pro) but I don't know where to look and I don't want to purchase some that shit out on me after a couple days or raise case heat.
Any suggestions are welcome, thanks.
I would just browse around on here and see the reviews for what's posted. As Enderman said, bitfenix alchemy strips come in blue and are highly rated too.
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2872816
I use Bitfenix Alchemy Connect. Works great. I like it though I can't compare it to anything else.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2872818
You can always replace the fans with LED fans like the SORsair AF 120 LEDs but if you don't want to do that, the best (but pricy) ones I know of are the Bitfenix Alchemy.
If you want something cheaper and something you can control and also illuminate a larger area all around the window, this is a good bet
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2872857
All premade LED strips are going to be made overseas, by the cheapest method possible, with no regard for warranty since they're so cheap and not worth the hassle for most consumers...so they will ALWAYS be a shot in the dark and hoping you got a well built one.
see if any of your friends can solder, then make your own with a bunch of leftover 12V molex fan adapters that you probably have lying around
otherwise just pick whatever. they're LED strips - nobody is going to hire an engineer to build or QC them
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2872894
Are they of good quality and bright(not too bright)?
Yes they are great quality, and are pretty bright. You will only need one or two to light up a full tower case.
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2873340
This is a 60cm white Bitfenix Alchemy LED strip: (running along the top and around the right side--by drive cages).
Note: There is a bright dot in the top right corner since it wasn't fully attached at that time and the diode wasn't hidden.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2873362
Where should I purchase them, their site or somewhere else?
Posted Image
They look pretty and that is a pretty sexy rig(blue is my favorite color). :P
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2873415
Newegg, FrozenCPU, or whatever retailer you prefer that has them.
iceModz also has good (or so Ive heard) LED strips.
Mine as well.
PSU Tier List | CoC
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2873433
Mine as well.
Ok thank you. One more question, hiow do you choose a motherboard with the right color?(blue or black since motherboard manufacturers don't provide a choice for colors.)
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2873472
You have to just look for motherboards with that color scheme. PCPartpicker.com has an option for colors, although, I don't remember how helpful it was...
What color scheme were you going for? Black/blue? If so, then id go with the MSI Z97s SLI plus (thats what I have). I'd also think more about what color LED you want before ordering. I feel like a blue LED would be overwhelming--hence why I went with a white LED.
PSU Tier List | CoC
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2873497
Right, almost half my rgb lights display the wrong color now
https://linustechtips.com/topic/211657-leds-for-pc-case/#findComment-2874018
