post-122015-0-87099200-1410176655_thumb.
This is a mazak optiplex 3015. It's a cnc controlled laser cutting machine which can cut pretty much any shape out of metal.I have access to this machine and I am planning on making my very own case. If you have any ideas which you wish was on a case what would they be?
https://linustechtips.com/topic/211585-ultimate-diy-case-ideas/
I would make it a special shape, not a cube or something. Maybe some kind of triangle (like the new Alienware X99 one from the Linus video) Or even a sphere. Not sure if it's possible but i'd make something very original.
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
https://linustechtips.com/topic/211585-ultimate-diy-case-ideas/#findComment-2872123
any game you really like? or show?
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/211585-ultimate-diy-case-ideas/#findComment-2872126
Space in the bottom and top of the case for three 480mm radiators (3 in the top, 3 in the bottom), each in it's own push pull configuration, one on top, one on each side (at the top and bottom) and one on the bottom, for a total of six 480mm radiators. Bottom radiators intaking and top radiators exhausting. Another row of 4 fans pushing up to the top of the case (pulling off the rads) and yet another set of fans at the top, pushing air into the exausting radiators.
Some sort of semi transparent, colored, UV reactive motherboard tray. (because reasons)
Dual rear exhaust fans.
A row of 80mm fans running down the side of the expansion slots (that little strip that's normally an open grate)
Hidden UV LED lighting.
Dubs are better than subs
https://linustechtips.com/topic/211585-ultimate-diy-case-ideas/#findComment-2874331
