32bit and 64bit
Go to solution Solved by 79wjd,
https://www.youtube.com/watch?v=IknbgnJLSRY
Basically, 64 bit is better if you need more than 4gb of ram
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/211321-32bit-and-64bit/#findComment-2868099
im waiting for 128bit...
im waiting for 64 gigaBYTE
https://linustechtips.com/topic/211321-32bit-and-64bit/#findComment-2868141
While the video's points are all true, this not necessarily means it will be no performance gain. What Linus didn't let all that clear is what a 64 bits processor can achieve, and that is being able to work with a "word longitude" of 64 bits, which means that with a better encoding and with software meant specially to work on 64 bits, it can process data twice as long, completing a task much faster.
However as he said, there is a lot holding as back, from compilers and APIs (not talking about graphic APIs) to our OSs, that still are developed for 32 Bits, making the jump to 64 pretty much a matter of memory. On an ideal world, we would move all our processes to 64 bits, and make all the CPU instructions to work with such big amount of bits.
There are specialized pieces of software and OSs that bring the benefits of 64 bits, and even for 128 bit processors, but only used in servers and mainframes, nothing aimed at consumers.
https://linustechtips.com/topic/211321-32bit-and-64bit/#findComment-2868302
Edzel's new rig:
CPU: Intel Xeon E5-2697 V2 2.7GHz 12-Core Processor  ($2526.81 @ SuperBiiz)
CPU Cooler: Swiftech H220-X 55.0 CFM Liquid CPU Cooler  ($154.99 @ NCIX US)
Motherboard: Asus Z9PE-D8 WS SSI EEB Dual-CPU LGA2011 Motherboard  ($534.98 @ SuperBiiz)
Storage: OCZ R4 1.6TB PCI-E Solid State Drive  ($11479.99 @ Mac Mall)
Case: Silverstone TJ07B-W-USB3.0 (Black) ATX Full Tower Case  ($372.83 @ Amazon)
Power Supply: Corsair AX1500i 1500W 80+ Titanium Certified Fully-Modular ATX Power Supply  ($449.99 @ Newegg)
Operating System: Microsoft Windows 8.1 Pro (OEM) (64-bit)  ($132.98 @ OutletPC)
Monitor: NEC PA302W-SV 60Hz 30.0" Monitor  ($2649.00 @ Adorama)
Keyboard: Happy Hacking Professional 2 Wired Mini Keyboard  ($282.00 @ Amazon)
Headphones: Sennheiser HD800 Headphones  ($1499.95 @ Amazon)
Other: Intel Xeon E5-2697 V2 2.7GHz 12-Core Processor ($2526.81)
Other: 64GB kit (32GBx2) DDR3 PC3-14900 Load Reduced ECC 1.5V 4096Meg x 72 ($1259.99)
Other: NVIDIA Quadro K6000 VCQK6000-PB 12GB GDDR5 PCI Express 3.0 x16 Workstation Video Card ($4499.00)
Total: $68761.26
Generated by PCPartPicker 2014-09-07 19:57 EDT-0400
I'm sorry, you wanted a MOUSE at that price?
"You have got to be the biggest asshole on this forum..."
-GingerbreadPK
sudo rm -rf /
https://linustechtips.com/topic/211321-32bit-and-64bit/#findComment-2869276
