I'm wanting to build up a Server/guest PC for some gaming and content storage and backup, I have the GPU, RAM and basically everything else, I need a CPU and motherboard.
What I'm trying to find is either Intel quad core or Hex core and a suitable mATX motherboard that supports DDR3.
I'm looking in the price range of £100 to £150 for both.
Can also be used parts
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
https://linustechtips.com/topic/206159-looking-for-cpu-and-motherboard/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£133.38 @ Scan.co.uk)
Motherboard: ASRock H97M Micro ATX LGA1150 Motherboard  (£21.86 @ Amazon UK)
Total: £155.24
Generated by PCPartPicker 2014-08-29 08:21 BST+0100
over by 5 quid but should fit
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Total: £155.24
What is the CPU like? Kinda also looking for something with low TDP and can be run if needed 24/7 was also looking into ECC memory....
oh Xeon will be great but not sure which board support ECC RAMs...
this is a locked CPU so TDP is not any problem
I think you'd need a C224 chipset for ECC on the Xeon.
Xeons are also binned for 24/7 use and lower tdp :)
I don't think that's gonna be a £150 job. I'd try pick up something like a used z77 board and a used i5 3330s.
you are correct, a xeon e3-1231V3 for example does support ECC ram.
however, you indeed gonne need a C-series chipset board aswell for ECC support.
and those boards, are kinda expensive.
@Lazmarr
Board and CPU are available on Amazon.
Needless to say it aint cheap. But there is an alternative.
You can get dual socket LGA771 board for like £35. Quad core Xeons on that socket for ~£30 and 16Gb of ECC DDR2 for £70.
You still got to power the thing though :P
