H100 o-ring mod
Go to solution Solved by Enderman,
Nope, nothing bad can happen.
So I saw this thread, which refers to the H100i.
I've got an H100 from a previous build that I am about to install in a new rig. When I used it previously I didn't notice any real issues. I'm always up to get more performance out of something, and if a simple O-Ring can help my cooler function better, then awesome!
Basically I'm just curious if there will be any adverse reactions from using those o-rings on my H100. I wasn't sure if maybe there was a mfg issue with the H100i mounts that the H100 didn't have, or anything similar.
https://linustechtips.com/topic/203510-h100-o-ring-mod/
https://linustechtips.com/topic/203510-h100-o-ring-mod/#findComment-2762921
