Graphics Card not allowing images to show up on my moniter.
Solved by MourningSouls,
Since you're using a TV, are you sure it's set to the right input? Some TV's I've used auto switch to new signals, others don't.
Other than that my only thoughts are that it's DOA or you derped and it's not actually plugged in properly.
Featured Topics
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning1 -
Xrniu ·
Posted in New Builds and Planning2 -
8
3
bleedpurple ·
Posted in Storage Devices2
