Internet speed slower through ethernet?
scaryjam823
So for some reason today my computer decided to not operate at my full internet speed. On wifi I get anywhere from 2700kb/s to 4000kb/s. My computer has always worked at this speed, until today. When I download something or try to load webpages it operates at a whopping 150kb/s. Meanwhile on my phone and other wifi devices I get my full internet speed.
I have tried the following to fix it:
Take my static ip off and let the router give me desktop an ip address - no change
Tried resetting everything in my router, from QOS to firewall etc. - no change
Tried ipconfig /release and ipconfig /renew - no change
Tried disabling all extra network adapters in device manager (hotspot shield, microsoft ISATAP #1-6, virtual miniport adapter 1 and 2, virtual box host ethernet adapter) - no change
Reset the router, modem and computer several times - no change
Tried a different ethernet cable - no change
Plugged a laptop into the router using a different cable and my desktop cable - no change
Tried plugging cable into different port on the router - no change.
I'm at a loss as to what it could be and have no idea what to try. When I run speed tests it starts at 150kb/s, jumps to 500 kb/s then back down to 150kb/s - 180kb/s. It feels like something is throttling my computer but I cannot figure out what it could be. It worked fine the last I was on my computer, went two days not being on it and I'm greeted with this problem. Any advice to look into would be greatly appreciated. Router is an asus rtn66u
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
Have you tried.... *drumroll*.... changing the cable? :D
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
Did you restart your computer?
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
Yes it is not the cable, forgot to mention that. The cable is only a few months old and a cat 6 cable. I just tried connecting a laptop to my router through both a different ethernet cable and the one going to my desktop, it had the same problem. That leads me to believe it is an issue with the router, it is an asus rtn66u. Computer has been restarted multiple times as well as the router and modem.
