This setup will work right
Go to solution Solved by helping,
Guyz?
270 or 265 is a better choice, if you can't afford that then 750TI it is.
That's not really debatable either.
Planning to have all the parts by christmass (excluding the PSU thats in my rig now put it there to make sure its enough) and i just want to make sure this will work. The motherboard and CPU Indefinate because i told my mum to get me a bundle with the two from NCIX for my birthday, others can be changed.
PCPartPicker part list: http://ca.pcpartpicker.com/p/k9cqrH
Price breakdown by merchant: http://ca.pcpartpicker.com/p/k9cqrH/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($124.99 @ NCIX)
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard  ($69.99 @ NCIX)
Memory: Kingston HyperX 8GB (2 x 4GB) DDR3-1600 Memory  ($89.99 @ Memory Express)
Video Card: Asus Radeon HD 7770 2GB Video Card  ($149.98)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply
Total: $434.95
Generated by PCPartPicker 2014-08-08 15:18 EDT-0400
EDIT: graphic card budget is 150 bucks
 The Wannabe is no longer. Replaced by the Flotilla. If you replace every part of a computer is it still the same computer?
Survived the Survivor 2299
Audio Engineer, Lighting Programmer, Video Engineer, FOH.
https://linustechtips.com/topic/194361-this-setup-will-work-right/
7770 is old. Get a 750 ti.
would be better off pushing it to a 270.
sure. but with 6300 and that psu that would be a shove.
A 750 Ti is about $130 in some places, much better for the money IMO.
A few more freedoms gets you a lot better performance.
http://www.amazon.com/dp/B00GN1Y43E/?tag=pcpapi-20
Not at all. 430w is plenty with extra for a 6300 and 270.
Error: 410
wrong dollar.
oh darn, nvm
I didn't know OP wasn't free
i always thought of canada as the most free country because they just dont give a fuck.  :lol:
So what should i get a 750 ti, a r7 265 or a r9 270? You guys are very confusing
R7 265?
Guyz?
do  you live near a microcenter ,.. you can get a fx 4300 for 40 bucks and spend alot more on your gpu ..the 200 is only about 20 bucks more to ... and im pretty sure a apu like the 7850k would perform the same here  which is 120 at microcenter
CPU and motherboard is already set -_-
Whats your budget, and you don't need an HDD or an optical drive?
It aint an entire build, just a most-of-the-computer upgrade
Incase anyone is curious i have decided http://ca.pcpartpicker.com/part/gigabyte-video-card-gvr7265wf2oc2gd
Its the r7 265
265 is like neck and neck or a few percent better than a 750 Ti last time I checked?
is it???
last time I checked
As far as I know, yes.
maybe i will go for the ever so slightly cheaper 750 then, can you think of any benifits for the r7?
Uh.... Mantle?
You might as well get an R7 270 gpu for less.
http://ca.pcpartpicker.com/part/powercolor-video-card-axr92702gbd5tdheoc
R7 270 doesn't exist... It's an R9 270. :P
