I'm looking at building my first system but I'm having trouble picking the components so I would welcome any suggestions.
- My Budget Is £1500 and my Location is the UK
-The system will be used for gaming. I will likely play a wide variety of genres
-I plan on running one 1080p monitor
- I also need a keyboard, mouse, monitor and OS
https://linustechtips.com/topic/192570-first-build/
Is SLI fine or do you want to prevent microstutter?
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/192570-first-build/#findComment-2609500
Windows 7 or 8?
https://linustechtips.com/topic/192570-first-build/#findComment-2609517
Mechanical keyboard (if so what switch) and do you plan CF in the future?
https://linustechtips.com/topic/192570-first-build/#findComment-2609531
IPS 60Hz or TN 120/144Hz?
Going with IPS 60Hz. Mouse and keyboard are personal preference really. You should look for that yourself.
https://linustechtips.com/topic/192570-first-build/#findComment-2609542
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£163.14 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.98 @ CCL Computers)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  (£87.56 @ Scan.co.uk)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  (£77.59 @ Amazon UK)
Storage: A-Data Premier Pro SP900 256GB 2.5" Solid State Drive  (£118.89 @ Amazon UK)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card (2-Way CrossFire)  (£275.94 @ Aria PC)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  (£94.99 @ Amazon UK)
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  (£99.99 @ Amazon UK)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  (£61.40 @ Scan.co.uk)
Other: windows 8.1 @G2a (£20.00)
Total: £1477.34
Generated by PCPartPicker 2014-08-05 20:57 BST+0100
https://linustechtips.com/topic/192570-first-build/#findComment-2609579
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  (£79.99 @ Amazon UK)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£60.32 @ Ebuyer)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  (£88.98 @ Amazon UK)
Case: Corsair 300R ATX Mid Tower Case  (£59.15 @ Aria PC)
Operating System: Microsoft Windows 8 (OEM) (64-bit)  (£72.77 @ Ebuyer)
Monitor: Asus VN248H 23.8" Monitor  (£154.98 @ Amazon UK)
Total: £1439.27
Generated by PCPartPicker 2014-08-05 20:49 BST+0100
Came up with this leaving you 60 pounds for mouse and keyboard. No need to go super expensive on them.
https://linustechtips.com/topic/192570-first-build/#findComment-2609581
if you don't need a monitor
Unfortunately he does need one.
https://linustechtips.com/topic/192570-first-build/#findComment-2609591
Motherboard: Gigabyte G1.Sniper B5 ATX LGA1150 Motherboard  (£75.00 @ Amazon UK)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  (£43.49 @ CCL Computers)
Power Supply: Corsair CSM 750W 80+ Gold Certified Semi-Modular ATX Power Supply  (£73.87 @ CCL Computers)
Monitor: AOC Q2770PQU 60Hz 27.0" Monitor  (£354.99 @ Ebuyer)
Other: Corsair MM400 Standard Solid Gaming Mouse Mat (£22.43)
Other: Superlux HD-681 Evo BK (£29.23)
Other: Cooler Master CM Storm Devastator Keyboard and Mice Bundle (£30.67)
Total: £1529.91
Generated by PCPartPicker 2014-08-05 20:51 BST+0100
Oh and windows from G2A
https://linustechtips.com/topic/192570-first-build/#findComment-2609600
@CoolBeans
To be fair I think my build is better. Mine has more storage, better memory, better CPU cooling and the better graphics card brand.
https://linustechtips.com/topic/192570-first-build/#findComment-2609601
Holy shit that thing is way more expensive than it needs to be.
https://linustechtips.com/topic/192570-first-build/#findComment-2609611
@CoolBeans
the motherboard doesn't support SLI so the crossfire will be in a PCIE x4 60 pounds for perihperals is going to get bad peripherals
https://linustechtips.com/topic/192570-first-build/#findComment-2609630
@SimpleG
That PSU is cutting it too close. Recommend getting the one I got: The EVGA 850W gold
https://linustechtips.com/topic/192570-first-build/#findComment-2609632
http://gyazo.com/38427aed6999152a93c79902841702b3
Doesn't support SLI but does support CF so it's fine.
https://linustechtips.com/topic/192570-first-build/#findComment-2609639
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£169.73 @ Overclockers.co.uk)
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  (£77.96 @ Scan.co.uk)
Memory: Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory  (£58.18 @ Amazon UK)
Storage: Crucial MX100 512GB 2.5" Solid State Drive  (£149.99 @ Ebuyer)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£51.54 @ Aria PC)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  (£275.94 @ Aria PC)
Case: Corsair 450D ATX Mid Tower Case  (£89.99 @ CCL Computers)
Power Supply: Fractal Design Integra R2 650W 80+ Bronze Certified ATX Power Supply  (£43.98 @ Scan.co.uk)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£11.05 @ CCL Computers)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (£71.60 @ Amazon UK)
Keyboard: Razer Blackwidow Ultimate 2013 Wired Gaming Keyboard  (£99.97 @ Scan.co.uk)
Mouse: Logitech G700 Wireless Laser Mouse  (£82.21 @ Amazon UK)
Total: £1362.12
Generated by PCPartPicker 2014-08-05 20:58 BST+0100
https://linustechtips.com/topic/192570-first-build/#findComment-2609661
I plan on CF eventually and if you were to pick out a mechanical keyboard, i'd probably prefer cherry mx browns
IPS 60Hz
https://linustechtips.com/topic/192570-first-build/#findComment-2609672
I know it does but it is going to bottleneck the bottom card, I updated mine anyways. 60 pounds isn't enough for a mechanical keyboard and mouse
https://linustechtips.com/topic/192570-first-build/#findComment-2609677
with one gpu he can squeez a 4k monitor in :D
Why would you even want a 4k monitor with one GPU? Dickwaiving rights? :D
@AlwaysFSX
Too much money in the SSD IMO and with this budget he should CF. He also plans to CF but hey he posted that too late for you :D. The 300R > 450D at a lower price. Dual R9 290's make upgrading to 1440p a no-brainer and give more performance for future games :P. It's not just about all them VRAMz...
https://linustechtips.com/topic/192570-first-build/#findComment-2609692
@AlwaysFSX
Dual 290s is pointless for 1080p.
https://linustechtips.com/topic/192570-first-build/#findComment-2609698
