Asus Xonar DG Sound card not working - Windows 7 Ult. 64 bit.
Solved by Faruko,
PCI\VEN_13F6&DEV_8788&SUBSYS_84471043&REV_00
PCI\VEN_13F6&DEV_8788&CC_040100
Everything in there, thanks mate.
Also, are you sure you have the correct drivers installed?
- Dump whatever Asus audio drivers you already have in ADD/REMOVE programs.
- Download DriverSweeper: http://phyxion.net/item/driver-sweeper.html
- Run in safemode
- Check off ASUS audio
- Analyze and clean
- Turn off pc
- Physically remove the card
- Put the card back in
- Restart normal
- Install the latest drivers from this site: http://ca.asus.com/product.aspx?P_ID=FiWODUF4uhiJVJKD
- Install as Admin
- Don't give up
