Be Quiet! Dark Rock Pro 3 :)
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2552858
You're missing NHD15 and Phenteks tower cooler
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2552859
i dont like the look of either of them.
CPU+Cooler: Intel Core i5 4690K @ 4.5GHz + Corsair H105 (Getting custom loop soon)  GPU: EVGA GeForce GTX 970 SC  RAM: Kingston HyperX Fury 8GB  Motherboard: Asus Maximus VII Hero  PSU: Corsair AX860i  Case: Corsair Graphite 760T Black
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2552879
You should probably prioritise performance over looks, but probably the best looking one with great performance would be the Dark Rock Pro 3
the cryorig r1 ultimate is apparently really good performing as well as having nice looks
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2552895
Noctua? No?
nah, not a huge fan of their ugly procucts.
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2553016
Replace the fans with their cheaper series?
they look bad as well lol. Noctua aren't the only good manufacturer that has good cpu cooling options.
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2553029
They're quiet, and very well performing. They're also pretty cheap(ish). They sell the NH-D14 for around £65, and I've sorta grown to like their looks :S
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2553035
the NH-D14 is ancient tho
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2553048
So? It still performs well.
tru dat
https://linustechtips.com/topic/189559-best-air-cooler/#findComment-2553057
