Possibly a stupid question, but have you installed the network driver yet?
Normandy - Intel Core i5 3470, 8 GB Corsair Vengenace LP, EVGA GTX 960 SSC, Gigabyte GA-Z77M-D3H-MVP, WD Blue 1 TB, Seagate 320 GB (steam), Seagate 320 GB (experimental, second OS, etc), Windows 8.1 + Ubuntu 14.10
Garrus - HP Stream 11
https://linustechtips.com/topic/188196-someone-help-me/#findComment-2533535
looks like he didnt -_-
https://linustechtips.com/topic/188196-someone-help-me/#findComment-2533551
the only other pc that I have is an Imac :P
There is a disk that comes with your motherboard that has all the drivers on it >.<
https://linustechtips.com/topic/188196-someone-help-me/#findComment-2533562
the only cds that I have are the windows one, the graphics card one, and the motherboard one :P
OK, if you have an optical drive, install the motherboard disc. It'll include your ethernet drivers on it.
https://linustechtips.com/topic/188196-someone-help-me/#findComment-2533570
Well I don't seem to find the driver... What should the driver say?
LAN or ethernet or network
https://linustechtips.com/topic/188196-someone-help-me/#findComment-2533583
That's okay as well, but the drivers on the disc are usually not as "up to date" as the one's on the gigabyte website. The importance of getting them from the website depends on how significant the updates were.
my question is, how am I going to do that if my computer doesn't have internet and my other computer is apple
https://linustechtips.com/topic/188196-someone-help-me/#findComment-2533636
