Dell Desktop: Fan Issue
Go to solution Solved by brownninja97,
I have a Dell Inspiron 580 desktop, it has a rear 92mm Foxconn fan, but since the 5450 barely makes any heat, I took it out. It's much more quieter and I have no heating issues.
However, when I boot it up, it says "Fan not detected, F1 to startup, press F2 to Set BIOS Options". The Dell BIOS is so restricted, you can't change anything about the fans. I don't want to purposely have a noisy fan (it's actually an HTPC), and have to press F1 every time I boot up.
Yeah i have a lot of knowledge with dells motherboards, you will need another fan or it will bitch out, the 92mm fan that i had in my 620 wasnt too bad, it hits 1200rpm, the bios is restricted because its h61, h61 barely has any features, gigabyte and asus have nice skins but they are basically are all limited big time and then again its not like any other features are needed, how many people are using insprions to get some crazy gaming build, the number is less then 200 inclusing you and I.
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/
Find a quiet 92mm fan and put it in. Hell, put a LNA on a really quiet 92mm fan.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524164
No. Why put an unnecessary fan?
So you don't have to deal with the F1 crap.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524182
The HD 6750 that came with my pre-built was super loud. Even my 10x more powerful R9 270 is waaaaay quieter.
5450 is passively cooled. The ref card comes with a 40mm fan. Yeah. 1 cm of it is the bearing itself. I can't hear it. When I turn on the PC, you hear it roar, but now it's silent. A 6750 is a low end gamer card, obviously that's loud.
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524207
Destroy the Dell with an axe and build an HTPC. The only way to fix it.
hehe i have the insprion 620, its more powerful then your pc. no axes were used.
Listen if you care.
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524297
Listen if you care.
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524315
Can I stick a random 3 pin shit in there?
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524330
set it on fire and build a PC yourself, always fixed my problems in the past
CPU: AMD FX-8120 | CPU Cooler: Thermaltake Contac 30 | Motherboard: GIGABYTE GA-990FXA-UD3 | Memory: Kingston 16GB (4 x 4GB) DDR3-1333 | Storage: WD 1TB | GPU: Gigabyte Radeon HD 7870 | Case: Thermaltake Chaser MK-I | PSU: Thermaltake Black Widow 850W
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524342
Yep and heres an example
Listen if you care.
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524920
Specs?
i3 2120
Dell motherboard, i used to know the name but i forgot now, its H61 chipset based
4gbx2 g skill ares 1866mhz(downclocked to 1600mhz due to chipset limitations)
XFX radeon 7870 XT limited golden core edition(in the case that you didnt know the xt edition of the 7870 uses a tahiti core which has 250 more stream processors(then xfx made a limited edition of it for high binned cores, i can push mine up by 300mhz in the winter))
Coolermaster Gx650 bronze(dont judge, it was on sale at the time)
Zalman Z9 plus
Before you ask about cable routing I know its bad, at that time i thought id be getting a new motherboard and processor, i brought a Gigabyte Z87x UD5h but then i never got the processor.
Listen if you care.
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524963
i3 2120
Zalman Z9 plus
It's basicly the same performance :P
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2524978
HAHAHAH no its not, mine is more powerful and then it can be overclocked more, the thing cost about the same price as a higher tier 7950 but ariapc did a 30% sale on it so i got lucky, brought it down to the gtx 660 league of which was a no brainer at the time.
Heres a comparision
http://www.techpowerup.com/gpudb/b1743/xfx-double-d-hd-7870.html
http://www.techpowerup.com/gpudb/b2638/msi-r9-270-gaming-oc.html
Listen if you care.
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2525014
I didn't know people still bought Dells who weren't being cheap with their business or school district. Its easier than ever to build a system... proprietary and locked bios are disgusting.
I bought it when I knew nothing about computers. I was 10. Now my parents use it as a HTPC, while I built my own gaming system.
https://linustechtips.com/topic/187563-dell-desktop-fan-issue/#findComment-2526405
