Hey there guys,
I'm looking to build up a powerful computer capable of sophisticated projects in vfx (after effects) a decent punt at 3d with Cinema 4d, and editing/grading at 4k.
Would love to read your thoughts on builds that would be powerful and stable.
The budget I have is approximately $12,000!
https://linustechtips.com/topic/186215-12000-vfx-editor-build/
Well, it would be doing some real churning with some pretty sophisticated VFX compositions and builds, ie film special effects. Yep I'd deffo appreciate your suggestions for a build spec list :)
You don't need a $12000 pc to do that..........
https://linustechtips.com/topic/186215-12000-vfx-editor-build/#findComment-2504558
I HIGHLY suggest waiting 2 more months for haswell e
Two Xeons would be more appropriate for this workstation build.
https://linustechtips.com/topic/186215-12000-vfx-editor-build/#findComment-2504619
Hey there guys,
Was not clear if monitors were part of the budget. So I took the optimistic approach and assumed they were not. I also only provided basic storage.
So, as others have suggested, a dual Xeon system with 64GB of memory and a Quadro K6000. Note the second Xeon at the bottom since pcpartpicker will not allow two cpu even with a dual cpu motherboard. The K6000 is also there because pcpartpicker does not list it.
CPU: Intel Xeon E5-2690 V2 3.0GHz 10-Core Processor  ($1947.94 @ SuperBiiz)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($62.99 @ Mwave)
Motherboard: Asus Z9PE-D8 WS SSI EEB Dual-CPU LGA2011 Motherboard  ($534.99 @ Amazon)
Memory: G.Skill Ripjaws Z Series 64GB (8 x 8GB) DDR3-2133 Memory  ($700.98 @ Newegg)
Storage: Samsung 850 Pro Series 1TB 2.5" Solid State Drive  ($699.99 @ Amazon)
Case: Phanteks Enthoo Series Primo Aluminum ATX Full Tower Case  ($239.99 @ Amazon)
Power Supply: SeaSonic 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($277.04 @ Newegg)
Optical Drive: Asus BW-16D1HT Blu-Ray/DVD/CD Writer  ($94.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.99 @ NCIX US)
Other: NVIDIA Quadro K6000 VCQK6000-PB 12GB GDDR5 PCI Express 3.0 x16 Workstation Video Card  ($4999.00)
Other: Intel Xeon E5-2690 V2 3.0GHz 10-Core Processor ($1947.94)
Total: $11658.83
Generated by PCPartPicker 2014-07-24 16:36 EDT-0400
https://linustechtips.com/topic/186215-12000-vfx-editor-build/#findComment-2504909
