be quiet! Dark Rock Pro 3/Noctua NH-D15
https://linustechtips.com/topic/186192-help-with-air-cooling/#findComment-2504281
Is there a reason why you are going with a 4790k instead of a 4690k?
Also you seem to be a razer fanboy....there are much better options on the market than razer.
https://linustechtips.com/topic/186192-help-with-air-cooling/#findComment-2504287
while the kraken is shit, the mouse is one of the best on the market, and the keyboard used to use cherry keys making it just as good as any other mech using them
Proud Member of the Glorious PC Master Race
https://linustechtips.com/topic/186192-help-with-air-cooling/#findComment-2504310
It's not just that, but also the flimsy build quality and cheap plastic they use in their products.
https://linustechtips.com/topic/186192-help-with-air-cooling/#findComment-2504317
Do you know anyother Good headset?? for max 100$ ??
kingston's HyperX Cloud is supposed to be great, tho im using a pair for 450$ headphones soo yea.. calling anything that cheap great kinda makes me questions their knowledge :P
https://linustechtips.com/topic/186192-help-with-air-cooling/#findComment-2504328
Do you know a good headset for 100? or max 150$
Mod mic + quality headphones.
Headsets are just bad.
Linus has reviewed a ton of headphones in a bunch of price ranges, I suggest you check those out.
https://linustechtips.com/topic/186192-help-with-air-cooling/#findComment-2504334
I don't know where people get this from. I own a razer keyboard, mouse and headset.  Yes if I knew what I do now at the time, I would have gotten a different headset.  But the build quality is excellent and the plastic they use is anything but cheap.
I seriously don't know why people say they make shit products, overpriced? yes. bad quality? far from it.    I am very happy with razer, their customer support has been great in the past and I would take my blackwidow ultimate over my freinds ducky shine 3 anyday.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/186192-help-with-air-cooling/#findComment-2505133
