budget? socket?
Specs
https://linustechtips.com/topic/183496-cpu-cooler/#findComment-2465882
If you want a low-profile cooler (it's not necessary) - Thermaltake AXP-100
If you want a tower heatsink - Cooler Master Hyper 212 (nice value), Be Quiet Dark Rock 3 (awesome looks, great performance, awesome looks again)
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/183496-cpu-cooler/#findComment-2465925
If you go with the 350D which i would highly recommend ( i love Corsair) there is room for an Corsair H100 so you can do some decent overclocking, or if you wanna run stock speeds set it to slow fan speed mode (so it will run virtually silent) and it will still keep your CPU cool.
https://linustechtips.com/topic/183496-cpu-cooler/#findComment-2466007
Does a 212 Evo/Rock 3 even fit in a 350D?
Was looking at a few low profile and coolers and can't be arsed to go with an AIO.
https://linustechtips.com/topic/183496-cpu-cooler/#findComment-2466142
Well, the Arc Mini R2 and 350D are pretty similar in terms of size, and in my Mini R2 the Dark Rock 3 fits nicely. Hyper 212 is a bit smaller.
https://linustechtips.com/topic/183496-cpu-cooler/#findComment-2466151
