Project Taurus
Royal_Rasta
hello,
project taurus is my first liquid cooled pc build, and i have to say it was fun and exiting at the same time,
setup: case: nzxt switch 810
mobo: asus maximus formula V
cpu: intel i5 3570K
gpu: asus gtx 690 (gonna ad another one in the near future)
psu: cooler master silent pro m2 850Watt
pump: ekwb dcp 4.0
rads: 360mm rad and a 140mm rad (both from ekwb)
ram: corsair vengeance 16gb (2x8gb)
ssd: 2 samsung 840 120gb
hdd: seagate barracuda 500gb
reservoir: ekwb x3 150
waterblocks:
cpu block: EK-Supremacy Clean CSQ - Acetal gpu block: EK-FC690 GTX - Acetal + Nickel + back plate.
some fittings and other stuff
post-8953-0-52920100-1369066815_thumb.jp
the fans i'm gonna use
post-8953-0-42506400-1369066825_thumb.jp
shipping from ekwb :)
post-8953-0-70224800-1369066832_thumb.jp
size comparison vs phantom 410
post-8953-0-16872600-1369066840_thumb.jp
post-8953-0-56496200-1369066848_thumb.jp
post-8953-0-38344800-1369066855_thumb.jp
THE GTX 690!!!
post-8953-0-88484000-1369066862_thumb.jp
it's a shame to dismantle such a beautiful card.
post-8953-0-71706300-1369066869_thumb.jp
post-8953-0-86986100-1369066878_thumb.jp
The result:
post-8953-0-15517100-1369066887_thumb.jp
post-8953-0-07567100-1369066895_thumb.jp
post-8953-0-12597200-1369066903_thumb.jp
post-8953-0-78573000-1369066908_thumb.jp
post-8953-0-43796700-1369066916_thumb.jp
Nzxt switch 810 -- Intel i5 3570k @4.2Ghz(water cooled) -- Asus Maximus V Formula(water cooled) -- 2x  GTX 690(water cooled) -- Corsair AX1200i -- Corsair Vengeance 16GB -- samsung 840 120GB (2x) -- Seagate Barracuda 500GB -- 3 Asus 24" screen's -- Corair K70 -- EKWB watercooling blocks and rads --
I can't help but not love the Switch 810. It's such a brilliant case for watercooling.
As I have said probably probably a hundred times I love red and black builds and although this doesn't take the cake it's still pretty good.
Cable management is like all watercooled builds, brilliant as always. You should try sleeving your own cables next time :D
Another awesome build log. Thanks :)
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
Spazzing on your color scheme! RED AND BLACK IS THE WAY TO GO!
Though can you shorten the connection between the mobo and Cpu block?
Maybe add another 120 rad at the back below the 360 rad? like such
120 Rad
then maybe sleeved cabling? :D
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
yeah the switch is great for watercooling :D
i got a corsair red sleeved cables set but thats for with my next power supply that i'm gonna buy when i buy the other 690.
thanks :D
i tried it but i got a kink in the cable then, it's weird because i've seen people with a shorter connection.
sleeved cables are coming with the next upgrade :D
Nice job mate! I recently just finished my first PC build too, know what u mean by fun and exciting at the same time.
thx, this wasn't my first build (it was my 3th) but yeah it really is like that :D
you posted some pics of your pc??
ohok cool, yeah I reckon i'l be doing this for a while now, is a really fun hobby! Yeah just posted my build tonight.
Looks very good :), you can't go wrong with red and black!
That usually ends up adding extra tubing  which looks bad and gives little added benefit :(.
Sweet build I love the colour scheme, what coolant did you use?
The first step to insanity is believing in your sanity.
ek blood red coolant
Looks nice but a little bit too long tubing, still a nice build :)
thx, i know it was my first build and i didn't want to get any kincks, but i'll try to make it look better with the next update of my rig :D
Pretty nice looking build. I usually prefer seeing the least amount of hose but the way the hoses curl with each other I like
thx. i'm gone try to shorten them. and the curls are just coincidence.
