Gigabyte HD Radeon 7970 gaming help...
Solved by Prodigydeadeye,
The 7970 is definitely not overkill for one display. Get it. It is way better than a 750ti. 750ti is a budget entry level card.
Featured Topics
Od1sseas ·
Posted in Operating Systems1 -
amaliasugar ·
Posted in Graphics Cards0 -
2
Louscou ·
Posted in Troubleshooting2 -
1
nulcow ·
Posted in Laptops and Pre-Built Systems2 -
2
1
SteffanF ·
Posted in New Builds and Planning3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
