Asus or evga I reckon, and I think the msi twin frozr is better than the windforce cooler as well.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
My vote goes for EVGA ACX Cooling,
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
EVGA usually has the best ones. MSI has a few good ones. Windforce ones are kinda good but they are noisy. Do a proper seach on the internet before deciding (i recommend youtube cooler comparisons, they exist)
I will be using a Fractal Design Define R4 case, so will you be able to hear the Windforce card?
You are... the biggest... Galaxy fanboy...
As sexy as a graphics card can be.
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
Gigabyte is generally pretty good, plus they have a UK office/warehouse unlike most other GPU manufacturers. This means should something go wrong you'll get your RMA turned around quicker. People will lick EVGA's arse, but if your card goes tits up you'll have to send it to Hungary, apparently.
The two here I'd go for would be MSI TF, since it's cheapest, or Gigabyte Windforce since it's only slightly dearer.
EVGA is generally the best option except for extreme cards like MSI lightning or Galaxy HOF. So MSI Lightning, EVGA ACX, MSI Gaming, Gigabyte Windforce, Asus DCUII, Zotac AMP.
Although not for the 780 EVGA holds the record with the K1NGP1N card for the 780Ti so for High end I would not count them out.
Then why mention the Kingpin since the OP was asking about 780s?
You said that in general EVGA is not good for most extreme cases. I was just pointing out that they are fine in extreme cases. But I guess I am getting a little off topic.
