Hey guys,
I'm wondering if anyone here has an NZXT H440 and knows how the airflow is inside of it? I like the case because it looks nice and is silence optimized, but if it has bad airflow then I'll have to find something else because I live in an area that gets pretty hot in the summer.
https://linustechtips.com/topic/179934-nzxt-h440-airflow/
It's good if you do not use the stock fans and use high grade fans that are better then the stock fans.The stock fans give ok airflow but not the best.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417152
I was planning on buying some Noctua or BeQuiet! fans, or some other quiet fan that can also give good airflow. :)
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417171
Then you will get good airflow in the case :) The airflow is not that restricted as some would think, but I highly do not recommend the stock fans, they just do not push enough air for the limited amount of air that can flow through the case..
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417183
Hey guys,
Good cooler and good fans will do the trick, it's not thaaat restricted, but is still more restricted than the average case.
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417186
The H440 has bad airflow but when you're watercooling you usually have overly good temps anyways so it's not a big deal. You can not watercool in that case just fine but I would go for another case if that were the case (huehuehue) even though I love the look of the H440.
If you are going to buy a lot of fans the corsair fans are good for the price. £16 for a dual pack (120mm as I'd put 120's in the H440) and the fans have voltage step down adapters so you can just run them at 7v from the fan splitter. The Corsair fans aren't the best by faaar but they look sexy, perform fairly well, very quiet at 7v and are cheap. Noctua fans are awesome don't get me wrong but the money you can save + the sexy looks are worse the like 10% worse performance in my opinion.
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417248
I don't plan to OC or use watercooling, just air cooling, does that make any difference? @fringie @HerEscutcheon @Zelx @ericlee30
Still fine.
Like others said get noctua's or be quiet or silverstone ap123 (proven quieter than nf-f12 in some cases)
Or see if there are any other cases you like
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417587
Still fine.
I'm not set on any one particular case, I just want it to be silent and I'v heard the H440 is very silent. I'll look around and see if there's anything else that's a bit better. :)
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417631
Price range?
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417639
Around $120 CAD. If it's a nice case I don't mind going a little higher, I'm not going for flashy though. I'm mostly using this just for work/games
Dark rock pro 3
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417728
No not at all, Im doing a watercooled H440 at the moment for my wife and my daughters H440 is all air cooled. I took the stock fans out of my daughters H440 and replaced them all with Bitfenix spectre fans in the H440 and you can tell a huge difference from the stock fans to the bitfenix fans in the case. I could see a even bigger improvement going with the Noctua or BeQuiet! fans.
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417754
Dark rock pro 3
Ohh, you meant price range for the cooler. Yeah lower than $130, but I'll take a look at that.
I'm really glad to hear that actually. How quiet is the case with the fans?
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417780
Sorry wrong thread.
Corsair 550d
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417790
The bitfenix fans are pretty quit even without sound dampening material in a case, with the H440 you can hear them but it is very subtle sounding  ( barely can hear them unless you are really just trying to hear them )
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2417815
I honestly didn't like the case at all after awhile. Hard to do cable management. Pain to get the case on. Hard to fit the 780. Not enough airflow at all. Yeah, better fans will improve airflow but the case is so restricted. Get the 750D for about the same price. You get tons of room, front bays for a CD drive (windows installation future proofing?), and much better airflow.
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2418256
I use be quiet fans on mine for intake, they're much better than the stock fans. In terms of airflow, I wouldn't worry too much about components overheating or anything. That being said, you're rig will definitely run hotter than if it were in a haf 912 for example.
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2418358
Well you should be perfectly fine then even with stock fans at 3v or 7v.
CPU temps are easy to control when not overclocking. Your graphics card wont benefit from 'better' fans, the CFM is usually pretty good with stock fans on cases. They just aren't uber quiet so if 7v isn't quiet then put them on 3v. If you put them at 3v you'll have no problems as the case comes with 4 fans.
Buying fans in your case (all dem puns) is kind of pointless. You don't need better fans. You might need to buy some step down voltage adapters though.
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2418645
Hi,
I like my case,h440 so much. Here is my rig setup,maybe can give you some idea from it...cheers
That actually looks really freaking cool, but a bit restrictive. I'm leaning more towards the Corsair cases now, even if they aren't silence optimized. They seem to have better airflow which is perfect since I love somewhere that gets really hot in the summer.
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2428812
A 750D with Cougar fans is really quiet. I still have my NZXT rad fans and one more AF140L as the exhaust. It is significantly quieter going with Cougar fans. Corsairs are the fashion statement in PC's. You will honestly rarely see the Cougar fans to give two shites about it.
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2434307
I decided to go minimalistic and sleek and went Fractal Design Define R4. It had the best reviews from everyone including Linus and is on sale right now. I just need to place my order and hope everything arrives in perfect condition by friday. I wanna game this weekend :P
https://linustechtips.com/topic/179934-nzxt-h440-airflow/#findComment-2436045
