 Hi Guys
I am running a tripple screen setup what would i need to upgrade or fix. to achieve 40+ FPS preferably 50-60FPS on tripple screen 5600x1080
· CPU - Intel 2nd-gen i7 3770K 3.2GHz(3.9GHz Turbo) 12MB Cache
· CPU Cooler - Corsair Hydro Series H80 CPU Cooler - All In One Liquid cooling
· Motherboard - ASUS MAXIMUS V Formula 6-Core Ready Quad-Chn DDR3 USB3 SATA3 CF/SLI Ready
· RAM - Gskill 8GB(2x 4GB) DDR3 1333
· Graphics - HIS 7970 3gb.
· Graphics - HIS 7970 3gb. xfire Bridge
· Primary HDD - Intel SDD160 Series 3 160GB SSD SATA III 6GB/s Max Read/Write: 550/520(MB/s)
· Second HDD - 500Gb SATA 3
· Optical Drive - DVDRW
· Case - ANTEC P280 GAMING CASE
· PSU - OCZ Fatalty 1000w Modular 80+ Gold
· Tripple Screen Stand
· 3 Acer LCD Monitors G235H
https://linustechtips.com/topic/178960-battlefield-30fps-issue/
I'd go with dual 770 FTW editions.
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/178960-battlefield-30fps-issue/#findComment-2403717
I like to run
2 gtx 780 cards most likely, one might be enough
what setting are you using?, current gen and HD 7000 doesn't have that much diffrence, same old architecture. Next year I heard AMD and NVidia will start using next gen stacked memory.
Maybe it time to adjust expectation.
Have you tried turning some settings down..?
Lol, one isn't enough.
I like to run my games at full settings
https://linustechtips.com/topic/178960-battlefield-30fps-issue/#findComment-2403739
 for 40 to 50 at low settings :P
Because people spend almost $600 on a gpu and run at low settings :lol:
I like to run
Not happening unless you get 2x 780 Ti's or 2x 290's.
Due you guys think it could be due to bottle necking from the cpu, ram or HDD as i am not running it from the SSD. Or is this purely a GPU issue?
https://linustechtips.com/topic/178960-battlefield-30fps-issue/#findComment-2404408
So running the game just of a SSD won't help either?
Won't help FPS drops, or FPS in any way, what it will affect is load times, loading stutters and streaming textures, and limiting Windows background process's from interrupting your fluid gaming experience.
I know you love "Running everything at MAX"
What performance do you get with 2xAA instead of 4xAA... Out of curiousity? & is it THAT big of a deal for you to disable 4xAA for extra performance..?
It's only when your standing still when you'd (if Anal about it) notice it not being on full effect anyway.... and how often does that happen in any FPS game...?
I'm not digging at you, just plainly curious about your thoughts on using 2xAA @ Triplescreen vs 4xAA, is it that noticible?
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/178960-battlefield-30fps-issue/#findComment-2410536
Not related, I should make this a new thread, buttt I cannot see ANY difference with AA on and off in newer games.
https://linustechtips.com/topic/178960-battlefield-30fps-issue/#findComment-2410894
Couldn't notice the diff much frame rates went up by 2.  Just like being able to go flat out.
https://linustechtips.com/topic/178960-battlefield-30fps-issue/#findComment-2411600
