Its California.
I'm burning.
I'm debating whether to buy some 200mm airflow fans and sticking it to some bendable lamps to make a beast body cooler.
Regular fans (the not ceiling fans) are too noisy so I need something quiet.
Should I do this or am I absurd.
Oh yea and my mom will kill me if I switch on the air conditioning and so It is around 85 degrees in my room.
Gaming Rig: i5-3570k+H100i (4.3 ghz) | P8Z77-i Deluxe | MSI Twin Frozr 7950 Boost | HX650 | 1TB HGST | 840 Evo 250 GB
https://linustechtips.com/topic/178501-cooling-me/
I think you need some phase change cooling...
Got a stock intel heatsink lying around? Stick it to your forehead with duct tape. Helps a lot.
https://linustechtips.com/topic/178501-cooling-me/#findComment-2396814
Just move to Australia. Pretty damn cold here atm.
You mean move from Australia to USA to avoid summer all the time?  :lol:
https://linustechtips.com/topic/178501-cooling-me/#findComment-2396839
Try living in the warmest room in the entire building. Oh, it's great for winter, but during summer, it's scorching hot! It's not a dry heat either, it's almost a humid heat like in Florida or Louisiana. Air conditioning for whatever reason, can only make my room lukewarm while the rest of the building is cool. Going outside is cooler than staying in this damned room. Opening windows help only when there's a breeze or it's cooler outside. Otherwise, I'm having fun in a dry sauna. Hate my room (during summer).  :angry:
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/178501-cooling-me/#findComment-2396915
