What will these fans be used for?
proud owner of alienware 13 with graphic amplifier and also a alienware X51 gaming PC!!! really powerfulL!!
xoxo samantha <3
https://linustechtips.com/topic/177229-fans/#findComment-2377890
for cooling my pc
I hope they're going to be used to cool your PC.
Will these be used for intakes and exhaust in your PC chassis, or will they he used on a heat sink or radiator?
xoxo samantha <3
https://linustechtips.com/topic/177229-fans/#findComment-2378075
in pc chasis
Are these coolermaster fans the only options, or are you willing to branch out to different manufacturers?
If you are willing to check out some other options, what's your budget per fan?
xoxo samantha <3
https://linustechtips.com/topic/177229-fans/#findComment-2378118
it can be diferent but with blue led, 120 mm, and max 20 dollars
Bitfenix's Spectre and Spectre Pro LED are two good options. You can also check out corsair's AF line of LED fans.
These suggestions are based on your requirement to have LEDs. There are some much better options with no LEDs that will also be more quiet. You may want to look into an LED strip and something like this.
xoxo samantha <3
https://linustechtips.com/topic/177229-fans/#findComment-2378177
Ap121 blue led
Ap122 (no led)
Ap 123 (no led, but bLue, it's my profile gif)
https://linustechtips.com/topic/177229-fans/#findComment-2380035
What kind of dollars are you using?
https://linustechtips.com/topic/177229-fans/#findComment-2401460
