Hi, i am currently planning my first computer build for the summer and i am wondering which pc build.
Budget: £800
Purpose: Gaming (BF4, LOL) and Coarsework
Option 1 : http://uk.pcpartpicker.com/p/yyfJmG
CPU: AMD FX-8350 4.0GHz 8-Core Processor  (£124.99 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.25 @ Scan.co.uk)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  (£79.19 @ Scan.co.uk)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  (£56.98 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£38.70 @ Aria PC)
Video Card: MSI GeForce GTX 770 2GB TWIN FROZR Video Card  (£221.72 @ Scan.co.uk)
Case: Corsair Graphite Series 230T Black ATX Mid Tower Case  (£62.39 @ Aria PC)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.93 @ CCL Computers)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer  (£11.74 @ CCL Computers)
Operating System: Microsoft Windows 8 (OEM) (64-bit)  (£72.88 @ Ebuyer)
Wireless Network Adapter: Asus PCE-N15 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  (£11.99 @ Aria PC)
Total: £754.76
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  (£155.94 @ Aria PC)
Motherboard: MSI Z87-G45 Gaming ATX LGA1150 Motherboard  (£82.64 @ Scan.co.uk)
Case: Cooler Master Storm Scout 2 Advanced ATX Mid Tower Case  (£59.99 @ Scan.co.uk)
Total: £786.76
After research here are the two systems that i created, what are peoples opinions and is there anything that i can get better for my budget?
Also i dont think i would be planing to overclocking the near future, what would any cheaper non overclock option be?
Thanks,
Zack
https://linustechtips.com/topic/175540-first-pc-build-help/
4670k for sure :)
You might want to consider x97 and the 4790k if it fits the budget.
Everything else seems all right to me :)
https://linustechtips.com/topic/175540-first-pc-build-help/#findComment-2344270
What's the system being used for?
https://linustechtips.com/topic/175540-first-pc-build-help/#findComment-2346236
Ill mostly be using it for gaming (eg: Battlefield and LoL) along with general use and coursework
You could get a ssd now: http://uk.pcpartpicker.com/p/vhNfFT
https://linustechtips.com/topic/175540-first-pc-build-help/#findComment-2346743
Thanks for the advice, i have been looking around and can get this for £800 :
http://uk.pcpartpicker.com/p/wWMJmG
CPU: AMD FX-8350 4.0GHz 8-Core Processor  (£119.99 @ Amazon UK)
Memory: Kingston Fury Red Series 8GB (2 x 4GB) DDR3-1866 Memory  (£60.38 @ Amazon UK)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  (£44.94 @ CCL Computers)
Video Card: MSI GeForce GTX 770 2GB TWIN FROZR Video Card  (£225.32 @ Scan.co.uk)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  (£12.52 @ Amazon UK)
Total: £802.48
Is this good for the price or is this tending to more Intel CPU territory price rather than an AMD build?
https://linustechtips.com/topic/175540-first-pc-build-help/#findComment-2360082
Here is an i5 build, although slightly over budget.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£155.94 @ Aria PC)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  (£87.94 @ Scan.co.uk)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory  (£54.48 @ Amazon UK)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  (£51.98 @ Aria PC)
Video Card: Gigabyte Radeon R9 280X 3GB WINDFORCE Video Card  (£201.00 @ Amazon UK)
Other: Superflower Golden Green HX 550W (£59.59)
Total: £832.88
https://linustechtips.com/topic/175540-first-pc-build-help/#findComment-2360184
Budget: £800
Total: £754.76
Total: £786.76
Thanks,
Zack
I know this doesn't really help much, but either system will play those games on ultra without any issue. Go with which ever one you want, you won't be disappointed in either one.
Which ever one you go with, use  Windows 8.1 instead. Win 8 isn't a good OS.
Gaming/Editing PC: AMD FX-8350 | CM Seidon 120V Liquid Cooler | Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard | G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600| Gigabyte GeForce GTX 770 2GB WINDFORCE | PNY XLR8 240GB SSD | Seagate Barracuda 2TB HDD | Corsair 600W ATX Semi-Modular PSU | Thermaltake Chaser A71 | LG 25UM64-S 25.0" 2560 x 1080 Display | CM Storm Devastator Gaming Keyboard & Mouse
https://linustechtips.com/topic/175540-first-pc-build-help/#findComment-2360441
Hi, thanks for the advice, I plan to go for windows 8.1 but on partpicker its listed at £78 but i can ge tit cheaper at my local pc store so i just left it as 8 as it was closer in price :)
Would you say both are equally future proof? as i would like to be able to get 3/4 years out of this build.
thanks,
Zack
https://linustechtips.com/topic/175540-first-pc-build-help/#findComment-2360506
thanks,
Zack
yeah, you can get 3/4 years out of either one with no problem.
https://linustechtips.com/topic/175540-first-pc-build-help/#findComment-2360744
