AAAAAAAAAGGGGGGGHHHHH!!!!
But could you use something like a GTX 770?
Or would that be useless?
I know you could do 6 with most AMD cards that have mini DP or DP and use a Multi Display Hub.
Asus had a 7970(I think) that had 2 DVIs and 4 MDP/DP that would run 6 monitors natively but trying for 8 may require a Display Hub.
You would have to check but some GPUs may let you use 2 Display hubs plus 2 ports on the card itself. But no one card comes to mind like that.
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
gaming on 8 monitor is crazy!!! no single gpu can power 8 screen at the same time. 6 is the highest for AMD cards
but for normal desktop it will be fine
that will be one heck of a huge viewing area with 8 screens thou
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
Problem here is that you have 4 ports to many and this makes the second card really not worth the money
What 2nd card?
