Sapphire r9 290 Tri-X - Low performance?
Solved by MonkeyFace,
Will try to reinstall the drivers again.
I've already tried that, but will do it again.
Thanks again!
Make sure you uninstall the drivers and delete all the folders and registry before reinstaling.
http://www.overclock.net/t/988215/how-to-remove-your-amd-ati-gpu-drivers
uzivkovic97 ·
Posted in Linux, macOS and Everything Not-Windows1 -
7
OctaviousTheHonorable ·
Posted in General Discussion1 -
4
6
Real_Smoky ·
Posted in Laptops and Pre-Built Systems1 -
TannerMcCoolman ·
Posted in LTT Releases2 -
2
3
