I'm about to build a computer and I'm not sure what components to go with. I am spending $4000(au) and the components I'm thinking on getting are:
cpu - Intel core i7 4790K
cpu waterblock - EK Supremacy Acetal/Nickel clean cpu block
Pump/Reservoir - EK DCP 2.2
Radiator -  EK Coolstream 360mm rad
Hard drive - 1TB WD black
SSD - Samsung 840 evo 250GB
RAM - Corsair Dominator Platinum 16GB 2400MHz
Motherboard - Gigabyte Z97X Gaming G1 Black Edition Motherboard
PSU Corsair AX1200i
GPU - GeForce GTX Titan Black
GPU Water Block - EK FC Titan
This is what i have in mind but im still not sure so if there is any better parts than what i got please tell me.
Thank you
https://linustechtips.com/topic/173273-4000-gaming-pc-need-help/
Ram of that speed isn't necessary.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/173273-4000-gaming-pc-need-help/#findComment-2301976
That power supply is pretty over kill.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/173273-4000-gaming-pc-need-help/#findComment-2301985
Power supply is overkill. You don't need a Titan, Get a 780Ti. The RAM is a bit silly.
Specs are on my profile page
 Teach a man to fish and he ends up sticking a screw driver in a turned on power supply seeing if it still works.        #KilledMyWifeWithABomb            Resolution is just a number
https://linustechtips.com/topic/173273-4000-gaming-pc-need-help/#findComment-2302023
